Charlie, you asked a few questions so lets take them in order.. ~You asked..... 1)- "I tried moving the distributor to find a spot where it sound better and I seemed to get rid of the backfires, but it still idles rough with the hunting. I have tried adjusting the idle screw and nothing happens.. I can close it completely and it still runs"...>>> Answ, that sounds like you have a carb idle circuit problem.. Try pulling the choke back on to see if the idle improves [it probably will].. Turning that idle screw all the way in should effect the idle, when that idle screw has no effect it pretty well tells us you have a carb idle circuit problem.. That will require pulling the brass carb circuit plugs & cleaning the effected passages & cleaning the idle transfer holes.. A plugged idle circuit is a common problem on those DLTX carbs.. Let me know if you need a carb cleaning diagram & I will send you one.. 2)-"I put a timing light on #1 wire and pointed it at the flywheel center opening in the flywheel cover to check the timing. The dot on the fly is about one inch to the left(towards front of tractor) from the dent mark on the flywheel cover as I face the flywheel. Is this normal or should the marks be aligned at idle?"...>>> Answ, that isn't normal.. The dot on the flywheel should line up with the flywheel cover dash [IF] the idle is low enough.. Try increasing the engine speed & watching with the timing light.. When the mark has moved as far advanced as it will go, then slowly lower the RPM & watch with the T-light, when the mark has moved as far as possible in the retard direction see if the RPM will come down lower? If it will & the mark doesn't move any more towards the retard direction you are at base timing & at that time the flywheel dot should be lined up with the flywheel cover dash.. [it sounds like you might have it too far advanced now, OR your idle is too high] 3)-"Can I mark degrees like 20 BTD and 10 BTD and so all around the opening and use these marks as a base to time it dynamically?'...>>> Answ, yes you can.. The only problem is the accuracy will be poor due to that small diameter hole but it will be close. 4)-"Since the opening is round , I could measure the circumference and then divide it into equal parts to find where the 20 degrees falls on the circumference?"...>>> Answ, yes.. the best way to do that is to measure the inside circumference, then divide by 360, that will give you inches per degree, then multiply that number by the degrees you want [20�], that will give you the distance to measure from the dash mark & put your advance mark.. 5)-"(for)instance if the circumference is 18in, then each 1 inch on the circumference would be 20 degrees. Is my thinking correct? Would this work as a means to where it can be timed correctly?"...>>> yes, 18"/ 360 = .05....05 X 20 = 1".. So 1" = 20� on an 18" circumference.. [easy as that] [email protected]
