CLOONY, 1 more question
Joe
07-09-2002 17:37:49
thanks for the pic, but im not sure which big nut i take out to access the valve.
thanks
Clooney
07-09-2002 17:48:32
 Re: CLOONY, 1 more question in reply to Joe, 07-09-2002 17:37:49
Joe, I sent you another picture..... ..
Joe, MORE
07-09-2002 17:47:36
well, i found it and it was the smallest big nut, and the valve is down in the hole and wont move, how do i get it out?
Clooney
07-09-2002 18:12:25
 Re: Re: CLOONY, 1 more question in reply to Joe, MORE, 07-09-2002 17:47:36
Joe, try a small magnet, if that won't work try a real small needle nose pliers [I use a hemostat(sp?].
~You might try cranking the engine with the PTO engaged to see if that will dislodge it. If it still won't come loose, reinstall the cap without the spring & washers & start the tractor. If it still won't budge you probably have something stuck in it...
