Detent adjustment
JD JACK
07-07-2002 19:43:44
Installed all new bearings and new springs for detents in transmission for late B. I just adjusted shift rails. Adjusted so gears are meshing up and detents are dropping into slot when gears are lined up. Is there anything else that I should be adjusting for transmission jumping out of gear in low range (1-3)? Did have replaced idle gear on countershaft, had some missing teeth. Not sure if that would cause it to jump out or not. Any advice apperciated,thanks.
Clooney
07-08-2002 03:46:26
 Re: Detent adjustment in reply to JD JACK, 07-07-2002 19:43:44
Jack, it sounds like you pretty well have it.
~Do all the rail & shifter gate slots line up when all gears are in neutral? If not they need to or the lever won't go through all the slots. ~Make sure all the gears are fully engaged when the detents are in the proper notches for that gear..... ..
