630 crank removale
david stiles
07-06-2002 18:09:49
Hi was try to get crank out any tricks to this may not have it turned just right yet would like to take crank and block and head to machine shop next week any suggestion the closes place from here that will do a 51/2 bore is atlanta Ga live in Franklin North carolina
thank you David Stiles
ChuckW
07-06-2002 19:45:38
 Re: 630 crank removale in reply to david stiles, 07-06-2002 18:09:49
there's not much of a trick, you have to removed the clutch, reduction side cover, flywheel, then you can remove the mains bring crank out, believe it come out on the crank side. Be careful also you need to retime the cam with crank when reinstalling, there are marks. Also some undersize bearings are not available. If crank is not bad, I'd never bother with removal if mains are good.
