JD 40
thomas
07-05-2002 20:21:17
I have a JD 40. How can I tell if its an S or C or U . IT is a 1953 year model.
Clooney
07-06-2002 08:02:25
 Re: JD 40 in reply to thomas, 07-05-2002 20:21:17
Thomas, if it's an [S] the final drives will be up right with the covers on the bottom,,,
~If it's a [C] it will have crawler tracks,,,
~If it's a [U] the final drives will be laid down with the covers on the rear.
~You also have the 40 special, 40 two-row utility, 40 hi-crop, & 40 T to consider.
~If it has a S/N plate it will be on the L/H side of the center frame just below the starter & will start with 40-S, 40-U, 40-T, ETC..... .
JDM Guy
07-06-2002 03:10:27
I believe it should say it on dash were the serial number is. Example.. 40U-11111 or 40-11112
thomas
07-06-2002 20:26:31
 Re: Re: JD 40 in reply to JDM Guy, 07-06-2002 03:10:27
thanks for the help
