720 ?
Ted
07-05-2002 18:49:53
Why does my 720 jump out of 5th gear going up hill? What is the fix and would JD have the parts i need? Thanks Ted.
Clooney
07-05-2002 19:12:26
 Re: 720 ? in reply to Ted, 07-05-2002 18:49:53
Ted, it depends on what is jumping out, 5th gear or the overdrive. ~Does the lever move out of the slot when it jumps out of gear?
~Does it jump out of second also? [assumes a regular quadrant with regular gear sets]
~Do you have the standard trans gear sets [1st in the upper L/H slot,or the optional 3rd/5th gear sets [1st across from reverse]?
Ted
07-05-2002 19:30:35
 Re: Re: 720 ? in reply to Clooney, 07-05-2002 19:12:26
Clooney, yes it comes all way out of slot in 5th gear. 1st is in top LH corner. 720 is a std if that makes any difference. Haven't tried it in 2nd. 3rd and 5th are on RH side of shift box at top. Ted
Clooney
07-05-2002 19:45:24
 Re: Re: Re: 720 ? in reply to Ted, 07-05-2002 19:30:35
Ted, if the lever is moving you probably have either worn sliding or counter shaft bearings, twisted or worn splines on the sliding gear shaft, worn splines in the 2nd/5th sliding gear, sever mis-adjustment of the 2nd/5th shift rail, worn detents on the shift rail, or a little of each.
~See if it pops out of second also, [they use the same gear sets]. If so you will probably have to go into the trans to find the problem
