45 JD B Again
Elkhorn Denny
07-05-2002 15:09:51
Fixed all coolant leaks and found a piece of dirt in carb. Thing starts right up and idols real nice now.
Problem: As soon as I start to idol it up, it wants to cut out. When the idol is up it seems to miss and puff smoke (Blue/Black) as well as backfire when it kills. Ive messed with all the adjustment screws on the carb & even moved the magneto to try to time it.
Please, what could be the problem. Im at witts end with this machine.
Clooney
07-05-2002 15:48:01
 Re: 45 JD B Again in reply to Elkhorn Denny, 07-05-2002 15:09:51
Denny, start by adjusting the idle stop screw, with the engine running at fast idle turn the idle stop screw in towards the spring until it almost touches. If it still acts up, turn the screw in a little at a time to see if gets better.
~If that doesn't stop the problem, make sure the throttle plate is sealing in the carb bore & isn't worn on the top & bottom where it contacts the carb bore.
~Make sure the throttle shaft bushings aren't worn & loose & if they go all the way through the carb side make sure they are flush with the inside of the carb bore. ~Make sure the spring is under the main nozzle & has enough tension to hold the nozzle up tight to the main well.
~Make sure you have a [blue] spark the will jump 1/4"+.
~Look closely for a vacuum leak at the carb to the intake manifold & at the manifold to the head.
~Try opening the spark plug gap to .040".
~There might be other problems that I forgot to mention, or you could have more than one of the above all added together.
~If none of the above help, post back for more things to check, we'll think of more.....
