John Deere 50 (pictures)
David Ransom
07-04-2002 16:19:26
third party image
third party image
Jason
07-04-2002 21:36:59
 Re: John Deere 50 (pictures) in reply to David Ransom, 07-04-2002 16:19:26
I and some friends have had good luck with brake fluid, get a quart and put about half in each cylinder wait a couple days and you might not half to beat on them at all, just some gentle taps and here they come
Tractorboy
07-04-2002 17:12:47
David, turn that block over and let them keep soaking. Smack um every day with the mallett and hard wood block but dont beat on the rod ends,and they will come soon. I use Kroil and it will soon break loose. I aint broke a piston land yet.
David Ransom
07-04-2002 21:04:52
 Re: Re: John Deere 50 (pictures) in reply to Tractorboy, 07-04-2002 17:12:47
Only one piston is still stuck. I don't think I've ever seen Kroil for sale. Where can you buy it?
Will P
07-05-2002 14:52:19
 Re: Re: Re: John Deere 50 (pictures) in reply to David Ransom, 07-04-2002 21:04:52
Here is the manufactors home page. Looks like you can order from them by using there 1 800 number. Try it.
Will P
PS I have used it and it is GREAT! I got it from my tool and die shop I work for.
JDM Guy
07-04-2002 17:03:17
Those pistons look like there in there good!!! I think the only way to get them out is bang on them.
Walt in Jaxn, Tn.
07-05-2002 12:24:21
 Re: Re: John Deere 50 (pictures) in reply to JDM Guy, 07-04-2002 17:03:17
david it looks like you have the right piston loose, i'd go ahead and take it out just to get it out of the way, then get two cement blocks and two boards to go on the cement blocks between the blocks and the tractor cylinder block. you may need to stack two extra blocks on the ground for clearance because you are going to knock the piston out the back of the cylinder block. place (stack) two cement blocks on the ground, one on top of the other on their edges so that you can see the ground looking down thru them, then stack two more on the ground the same way but parallel to the first stack and 6 to 8 inches apart, then place the boards (2x4) on top of the stacked cement blocks along the edges that are close to the other stacked blocks, with the 6 to 8 inch gap between the cement block stacks and boards pick the cylinder block with the stuck piston up and place it on top of the boards with the rod end hanging down between the cement block stacks but resting on the 2x4 boards. where the round cylinders extend out the back of the block should be between the cement blocks and boards, the cylinder block should be resting on the lip that runs along the top and bottom of the cylinder block that bolts the block to the crankcase. move the cement blocks and boards in against the round cylinders so the fit is tight. now when the piston and rod come out the bottom there will be some clearance so it will fall out. clean the block and piston up till it is dry with a cleaner (kerosene or varsol) wait till it dries good and then apply some heat down into the cylinder and up from the bottom not to heat it till it gets cherry red but just to complete the drying, a good way to find out if you are using to much heat is to spit on the top of the piston, if it sizzles stop the heat and go away and do something else for 5 or 10 mins. come back and apply heat to the other end of the piston. do this to both ends 4 or 5 times then while it's still warm spray PB Blaster down on the piston where it touches the cylinder wall, wait a few seconds and place a 2 ft. piece of that land scape timber i saw in the photo on top of the piston and try to drive it down with a bigger hammer than that dead blow i saw in the photo----- walt
