A
govenor 44, push lifer?, oil pump to be clean
JD 4000
07-04-2002 10:19:18
As I have the Govenor off. it seems needs to be cleaned before going back on, it has hard dark oil around in it, should I take it apart is't it hard to get it back together, are there something I need to do before putting back on, the bearing on the left side seem good. I have the push lifers part off too to be cleaned. any thing about oil pump part I have the gear part off too there is other 3 bolts from under should I take that off to clean?
