JD755 won't turn over
Curt
07-01-2002 15:34:22
Drove it into the shed. Next day it wouldn't turn over. Replaced battery. Turn the key to acc, no lights. I tested the ignition switch, it's fine. Voltage on acc and ign both stay at 0 when I turn on the key. If I pull the fuses out I get 12v at acc & ign on switch. Any suggestions as to how to diagnose the problem? Where can I get an electrical schematic for the 755.
THX for any help.
Clooney
07-01-2002 15:53:20
 Re: JD755 won't turn over in reply to Curt, 07-01-2002 15:34:22
Curt, if the [ign] & [acc] terminals on the ignition S/W have "0" volts with the fuses in & "12 volts" with the fuses out, you probably have a high resistance between the battery & ignition switch, or a low battery. [maybe at the starter or in the battery wire].. Check the voltage at the ignition switch feed wire with a load on the wire like a head light. ~I have a 755 but don't have a wire diagram for it. That little bugger hasn't given me any trouble in over 18 years.
~This wouldn't account for the voltage problems but make sure the mower lever is in the off position & BOTH foot pedals are in the center [either will not let it start]..... .
Curt
07-01-2002 18:05:38
 Re: Re: JD755 won't turn over in reply to Clooney, 07-01-2002 15:53:20
Thx, I can't get the headlights, or anything else, to come on in acc mode. Same symptoms at the switch. The battery is full charge. Don't no where to look for a high resistance load problem. I'm not familiar with the wiring path. If either of the top two fuses are in I get the drop in voltage. I too have not had problem with the tractor until this.
Clooney
07-01-2002 18:43:51
 Re: Re: Re: JD755 won't turn over in reply to Curt, 07-01-2002 18:05:38
Curt, if I get a chance I'll look at mine to see where the ign S/W is powered from, then send you the info..... ...
