JD MT
Austin
07-01-2002 11:28:53
I went out to run my 49 MT and went to start it and it wont start, I checked to see if I was getting spark and I was,I checked to see if i was getting fuel and I was, I tryed starting fluid and it still wouldnt start so I dont no what else to do.
Any info. will be appreiciated
Austin
JDM Guy
07-01-2002 15:23:44
 Re: JD MT in reply to Austin, 07-01-2002 11:28:53
Had my 51 M do the same thing. It turned out to be no air flow through the airstack. Also I have a MT that starts hard and I found out the carb gasket was no good.
Richard
07-01-2002 13:41:02
Check and make sure the carb is getting air through the verticle breather pipe. Found a mud dobbers nest in mine once.
Also
07-01-2002 13:43:52
 Re: Re: JD MT in reply to Richard, 07-01-2002 13:41:02
During the winter, I've also accidently flooded mine. But this is easy to find, as the gas fumes will be present.
