3010JD trans?
SAMMY
06-30-2002 19:42:54
I have a 3010 that seams to stop rolling kind of fast when I push in the clutch. I went to get it out of the shed the other day and it acted liked itwas locked up in 5th gear. I shifted into netrual it tryed to move forward. I then went into 3rd gear it popped then worked like usual until I shut the tractor off. IT went through this same thing again but has worked ok since [2times] any ideas what might be wrong? tia SAMMY
DON
07-02-2002 05:12:23
 Re: 3010JD trans? in reply to SAMMY, 06-30-2002 19:42:54
Sounds like you may have a gear trying to seize to the top shaft. Have you towed this tractor lately or run low on oil? Towing with out being in the tow position will turn the top shaft gears and they dont get any luberication. Just a thought. Don
