JD 2030 will not fire up
Simon
06-29-2002 16:23:06
My JD 2030 recently ran out of fuel and went dead. I replenished fuel but it will not fire up. I then tried to spray ether into the air breather, but will not fire up either. Can someone help?
John Henry
06-29-2002 18:40:15
 Re: JD 2030 will not fire up in reply to Simon, 06-29-2002 16:23:06
Open the air filter canister and remove the outer filter. Start cranking and give it a LITE shot of ether. It should fire but probably wont run on its own. You will have to bleed the fuel filter and injectors. Do the filter first then loosen the injectors. (Use two wrenches against each other) and then crank it till they start dripping fuel. It may start at this point. If it does, tighten the injector fittings. if it runs rough loosen each one and retighten it till it smooths out. Dont crank it more then 6 seconds each minute so you wont overheat the starter.
