JD B transmission bearing?
JD JACK
06-29-2002 09:14:19
Just got a new bearing from JD. Part #jd7159c sliding gear shaft lh bearing. One side of the bearing the balls are open, other side there is like a small plate with slots cut in it. Does anybody know which way this goes? I am thinking that open side would face the outside and the oil retainer would cover it. Bearing does not sit in oil, but there is a channel in case that directs fluid to bearing. Thanks for the help.
ChuckW
06-29-2002 11:53:13
 Re: JD B transmission bearing? in reply to JD JACK, 06-29-2002 09:14:19
the closed side is on the inside, to keep debrie from transmission from getting in the bearing
