Compression on a 630
Paul
06-28-2002 07:10:14
Can someone tell me what the compression should be on a 1959 JD630
CLW
06-28-2002 09:29:48
 Re: Compression on a 630 in reply to Paul, 06-28-2002 07:10:14
Paul gas - 6.20:1 All-Fuel -4.60:1 LP-8.10:1
G Taylor
06-28-2002 09:37:24
 Re: Re: Compression on a 630 in reply to CLW, 06-28-2002 09:29:48
Compression pressure should be 90-94psi all fuel at fast idle,gasoline 137-157psi & LP 216-237psi. Cranking pressure with electric starter and wide open throttle should be 84psi all-fuel,132psi gasoline & 185psi for LP. This and much more vital info is in the operators,parts & service manuals available from this site to help support it or from 1-800-522-7448.
