Disc Mower and JD 60 any one with any exp. Reply
Chris
06-27-2002 16:15:04
I have a 56 60jd i want to use a 6ft disc mower
I know there are people who dont use disc mowers with open cab tractors. I just want some suggestions on doing this. Its easier for me to do some mod. than to change tractors. Thanks in advance.
zane
06-28-2002 14:12:58
 Re: Disc Mower and JD 60 any one with any exp. Reply in reply to Chris , 06-27-2002 16:15:04
If you're talking about rotary mowers, I do it all the time using a 60 with an 800 3 pt hitch. A well-designed mower will have a housing that keeps most foward-bound missiles close to the ground. It may help to tilt the implement a tad so that the front is closer to the ground. Be careful going over rough ground or under low-hanging branches so you don't get wiped off the tractor. And don't back your rig into brush. You'll destroy your hitch.
