4020 Hydraulics Inoperative
Alan in Erin
06-27-2002 10:26:28
Hi Folks,
Bought a 1966 model 4020 Power Shift diesel. The 3ph and both remotes are slow as molasses in march, but the PS and transmission both seem to work fine. I've changed the fluid and filters, but no improvement. I'm going to check the hyd. pressure like the I&T manual suggests, but I'm wondering if there are other suggestions while I have her unbuttoned.
ET
06-27-2002 11:53:13
 Re: 4020 Hydraulics Inoperative in reply to Alan in Erin, 06-27-2002 10:26:28
Did you check the suction screen in the bottom of the transmission? It's probably full of old brake linings.
JDTECH
06-27-2002 21:28:55
 Re: Re: 4020 Hydraulics Inoperative in reply to ET, 06-27-2002 11:53:13
Check you're pressure, if it is low and the main pump doesn't seem to be sucking air, then check the stroke control valve in the main pump(front). If it has a groove worn into the seat, pressure is seeping by causing the pump to partially destroke which will cause your pressure to be low and your hydraulics to be slow. If you have more questions, e-mail me or repost. Good luck!
