JD 2010 spark plug problems.....
jay
06-27-2002 07:08:52
I have a john deere 2010 that has been a challenge to get running and keep running. It fouls plugs in less than an hour of operation. To remedy this I have, based on suggestions I have read in various groups, added extensions to the first two cylinders. A mechanic friend told me I may burn a hole in a piston. The tractor isn't worked very hard, mostly running a hay mower/conditioner. Should i be very concerned about damaging a piston?...jay
Bob
06-30-2002 09:34:51
 Re: JD 2010 spark plug problems..... in reply to jay, 06-27-2002 07:08:52
What Brand of plugs are you using - I ran autolite plugs and had the same problem....switched to champion - one size hoter and it has run great since...
jay
07-01-2002 06:59:01
 Re: Re: JD 2010 spark plug problems..... in reply to Bob, 06-30-2002 09:34:51
champion H10s were in it when I bought it. I tried H11s and now have H12s in it. It seems to start and run well. I'm concerned about what my mechanic friend said about burning holes in the pistons...jay
Bob
07-01-2002 07:32:56
 Re: Re: Re: JD 2010 spark plug problems..... in reply to jay, 07-01-2002 06:59:01
You might also try the ac delco plug that crosses from the champion number...I have 5 2010s and I use the ac delco plugs on most of them....seem to foul less....apparently a common problem.
jay
07-01-2002 13:03:30
 Re: Re: Re: Re: JD 2010 spark plug problems..... in reply to Bob, 07-01-2002 07:32:56
Thanks, Bob. I'll try them....jay
