Hydraulics Leaking Down
Tom
06-27-2002 06:38:54
Hey All,
Would using regular hydraulic fluid in a JD A power-trol instead of non-detergent 30W cause or just accentuate a leak-down problem?
Thanks in advance!
Clooney
06-27-2002 08:52:15
 Re: Hydraulics Leaking Down in reply to Tom, 06-27-2002 06:38:54
Tom, regular hydraulic fluid is thinner than 30W oil, so yes it would accentuate a leak-down problem. Now just how much worse the leak-down would get depends on where the cylinder or gasket(s) are leaking from, the type of hydraulic oil VS. the type & additives that are in the 30W & the temperature of both oils.
