JD M Tires
Pete
06-27-2002 05:23:31
Will 12.4 - 24 tires fit on stock JD M rims?
Ralph Ia.
06-27-2002 17:55:59
 Re: JD M Tires in reply to Pete, 06-27-2002 05:23:31
Sorry but I can't agree. My M has 8" rims on it. Now maybe your's are wider. Tire people have always told me not to use a tire that is over 2" wider than the rim. My M came with 10 x 24 tires. Thats the old numbers. The 11.2 is the same size and right for the M. A 12.4 would be like the old 11" tire and one inch too wide for that rim. You could mount them on there but because the side wall is squeezed down, only the center of the tire will touch the ground.
JDM Guy
06-27-2002 10:42:30
JH is right there is 12-26 rims thats what I have on my M. There shouldn't be any reason a 12.4-24 wouldn't fit on your M.
JH
06-27-2002 07:30:37
3 tire sizes were available from Deere when the tractor was new. They are: 8-24, 9-24, 10-24. I have 11.2-24 on my M and I see no reason that the 12.4-24 wouldn't fit. Beware that there are some standard size rims out the that are 26" also to fit the M. They are a bit rare, but they are out there, and they usually came with a 12-26 tire on them. Good luck
