How can I safely bypass the switch on my 70?
Doc
06-25-2002 11:03:53
I'm trying to get my old 70 running for the first time since I've owned it. I would like to hot-wire it so I don't have to worry about the wiring harness for now. Wires had been haphazardly taken off before I bought it. I connect a solid core copper wire from the negative terminal of the battery to the coil last night, but the wire started to heat up fairly quickly. I know the switch has a resistor in it, so is there any safe way of hot-wiring this old girl without hurting the coil? I just want to get it started so I can get it home. Also, can someone help me with troubleshooting a lack of spark. New plugs already. They look good, but should I get new plug wires? This thing ran well before it was parked in a shed about 5-7 years ago. A short at the starter was why it was parked. Do the condensor and points get bad from just sitting? I already cleaned the points. Thanks for your help.
Doc
Clooney
06-25-2002 15:17:48
 Re: How can I safely bypass the switch on my 70? in reply to Doc, 06-25-2002 11:03:53
Doc, you didn't say what type, model or S/N 70 you are working with. ~The early 70, [gas or all-fuel] didn't use a resistor & the later doesn't show one, but I have seen more than a few later 70's with a dropping resistor.
~That resistor on the switch was for the lights.
~You didn't say how long you want to run it?
~If just long enough to get on a trailer just use a jumper wire from the battery to the [non distributor side of the coil].
~If you want to run it long enough to drive it home you should check to see if it has a 6 volt coil [most say so on the case somewhere] or install a 12 volt coil. If it has a 6 volt coil either buy a ballast resistor for a late 60's or early 70's Chrysler product from the auto parts store [there cheap] or find the system resistor that should have been bolted to the front bottom of the steering support, then install the resistor in the wire from the battery to the coil.
~In most cases running a tractor that has a 6 volt coil on 12 volts won't hurt it & if the generator isn't working the voltage won't be much higher than the resisted voltage to the coil with a high limit on a fully functioning generator.
~As for your lack of spark; new points would be a good place to start & if that wire from the battery to the coil gets really hot & is a decent gage, maybe a bad coil.
