F- H Round Spoke rear wheels John Deere???
Sam F.
12-15-2003 20:35:14
Son just purchased an F-12 Farmall with F&H Round Spoke rear wheels. 20 spokes. They have part or casting # HC48C on wheels. He says they are John Deere yellow and paint appears to be original. What are they??? John Deere, Farmall, or ???
Duane Larson
12-16-2003 06:05:16
 Re: F- H Round Spoke rear wheels John Deere??? in reply to Sam F., 12-15-2003 20:35:14
Sam,
HC48C wheels are F&H wheels made for the Farmall F-12/F-14. They have 20-10" long spokes, 3/4" dia., most likely with 36x6.00S rims for 9.00x36 tires. The problem is the hub has a cast-in clamp designed for the F-12, and because of the hub not being fully splined, will not fit on JD tractors which have fully splined axles (as pointed out by others). It also looks much different than hubs on F&H wheels made for JD's.
I suppose it is possible to bore and spline the hub so it will fit a JD, but that would be a lot of trouble. I don't know why they would be painted yellow - F&H wheels sold through outlets other than the tractor manufacturer were painted a dark green.
Chooch
12-16-2003 05:21:34
Sam F.
The wheels are French & Hecht which was a independent manufacturer who sold wheels to both John Deere and Farmall, as well as others. Although I am not aware of the specific part numbers, I do know that the F&H round spoke rims off of a F-20 will also fit a JD GP.
Jon
12-16-2003 03:22:35
Sam -I am far from a wheel expert, and you should get replys from guys who are. However I do have two F-12's and neither have round spokes. They have flat spoke steel wheels.. The center hubs on a JD is either 10, or 12 spline for a "B". A F-12 has two keyways on the axle. So, if the hub fits the axle, most prefer the round spokes. I also have several J.D.'s and they do have round spokes but some have the flat cutoffs. Round spokes are more desired, at least on J.D.'s then the flat, but I don't know about the Farmalls. (Let me know if you want to horse trade!)
