AR, AO, BR, BO, Questions??
Wayne in Tn.
10-17-2003 09:25:28
I am only familar with the Dubuque tractors, but I like them all and have an intrest in any Deeres. I have always been somewhat confused at what a AR and BR is. I know the difference in looking at them, The AO looks like an orchard model. But what does an AR mean? The R is another tractor and surely the R don't mean Row crop, the AR looks like a standard to me. Just trying to learn, Wayne...
ET
10-17-2003 11:23:14
 Re: AR, AO, BR, BO, Questions?? in reply to Wayne in Tn., 10-17-2003 09:25:28
In AR or BR the R stands for regular. A left over from the days or all normal tractors being the standard low fixed tread design. The AR's usually had one transmission brake and AO's had a brake on each wheel. I just got ahold of one of each a 36 AR with the oil pump in the main bearing and redhead oil preasure indicator and a 36 AO with the offset radiator filler hole. The AO has the long hub round spoke front wheels on it like some GP's to give it the bean row spacing.
Wayne in Tn.
10-17-2003 12:00:27
 Re: Re: AR, AO, BR, BO, Questions?? in reply to ET, 10-17-2003 11:23:14
ET, thanks for the info. I just could not figure out what the (R) stood for. I knew there was a model (R) tractor. So (R) means regular and (O) means orchard? Are the models AR-BR-AO-BO more sought after than the normal A & B models? Thanks, Wayne.
ET
10-17-2003 12:53:08
 Re: Re: Re: AR, AO, BR, BO, Questions?? in reply to Wayne in Tn., 10-17-2003 12:00:27
They seem to have gone to pocket markets. So they are common in some areas and rare in others. Production numbers are less that row crops. The early AO's like the one I just found are kind of rare with around 850 built before the AOS replaced it in 1937. When the AOS was replaced by the plain AO again the radiator had a centered fill hole not offset like mine.
Wayne in Tn.
10-17-2003 14:16:50
 Re: Re: Re: Re: AR, AO, BR, BO, Questions?? in reply to ET, 10-17-2003 12:53:08
I grew up in the late fifties, in the South Tn. North Ms. and Al. area. I never seen any of those models. Everyone had row-crops, mostly tricycle John Deeres and Farmalls. About the only wide fronts I saw growing up, were Fords, even a lot of them were tricycles.
