J.D. G Clutch
Gman
06-25-2002 03:29:45
John Deere "G" clutch is slipping,inspected clutch disc appear ok,so I ordered new clutch toggles and dogs,helped very little. The operating sleeve I'm looking at now,I have a new one but this is my old work "G" sort saving for later date.I never have replaced an operating sleeve do you reckon this is the culprit?Would appreciate some input on this prblem thanks Garland
DP
06-25-2002 17:56:48
 Re: J.D. G Clutch in reply to Gman, 06-25-2002 03:29:45
Hi G-MAN! What year G are you having trouble with, and is it the snap-over, or the soft clutch? I find the clutch on my 38 G is hard to get the way i want it. Seems to have to be real tight, or it will pop out after a distance. I've also seen the holes in the sleeve get deep enough to cause the problem you are talking about. Even putting new Dogs ans Toggles wasn't enough to correct the problem without replacing the sleeve.
Tractorboy
06-25-2002 05:14:55
If it is slipping and the clutch drive is worn I have put an extra old disc in behind the new one and took up the play where it would adjust up .
