John Deere 2010 Diesel
Kevin
06-24-2002 18:46:08
I just bought a 2010 JD diesel tractor, I am having trouble with the fuel system. I changed the fuel filter, cleaned the sediment bowl, and also cleaned the screen filter at the injector pump. It has a new injector pump on it. It seems like its still starving for fuel. When I loosen the sediment bowl drain plug it seems like it's air locked? Anybody have any suggestions.?
Randy Hamilton
06-29-2002 09:54:52
 Re: John Deere 2010 Diesel in reply to Kevin, 06-24-2002 18:46:08
Pull the elbow fitting in bottom of tank, I have had them clog up at the 90
Steve in Tennessee
06-25-2002 18:30:00
I've had similar problems with my 2010 gas and also with my 60 gas. My problem was trash in the fuel tanks. The crud was settling in the shut-off valve coming out of the tank and cutting off the fuel. Once I drained and rinsed out the tank with some fresh gas, it cured my problem. The 60 had some varnish accumulated in the gas tank. It had sat for some years with a full tank of rancid gas in it. The stuff would periodically break loose and stop up the shut off valve. Once I got all that mess out, it solved that problem. I don't know if that is your problem, but it has the same symptoms as mine.
