Exhaust manifold bolts
Rod
06-24-2002 14:07:49
What do you guys think the best sealant is to use on the bolts that hold the exhaust manifold to the head? Thanks
Will P
06-24-2002 22:21:47
 Re: exhaust manifold bolts in reply to Rod, 06-24-2002 14:07:49
I don't use anything. Just use stainless steel nuts on the Deere studs. They don't rust.
Will P
Mike O
06-24-2002 19:39:42
Like G-MAN, I use a lot of anti-seize. I even wrap some teflon tape on the stud and then coat it with lots of anti-seize.
G-MAN
06-24-2002 14:38:39
If you use anything but liberal amounts of anti-sieze compound, you can rest assured that someone will be talking about you in the future - and not doing it in a flattering manner, lol. But seriously, I would never put anything but anti-sieze on any exhaust hardware. To be quite honest, I use it on a lot of different fasteners on engines I work on - aftercoolers on the newer Deeres, water pumps, fan bolts, oil cooler bolts, split bolts, etc. Anything you want to come apart easily in the future, anti-sieze.
David Ransom
06-24-2002 14:13:31
Absolutely without a doubt rust. The 50's manifold is now permanently attached to the head.
Bob K
06-25-2002 09:42:29
 Re: Re: exhaust manifold bolts in reply to David Ransom, 06-24-2002 14:13:31
Nothing beats heat, exhaust gasses, and rust to set threads (almost) permanently.
