JD 60 Powr-trol
JR Coffey
06-24-2002 11:39:36
I recently bought a Model 60 with the Powr-trol hydraulics. I have an operator's manual on the way, but in the meantime can anyone give me any details of operation of the Powr-trol part of the hydraulics? The shop manual appeared to show the remote cylinder attached between the lower arm and the rockshaft arm. Is the remote simply to adjust the height of the lower arm? Also, I only have a sliding control right at the remote valve connection, no lever that can be reached from the seat. Is this correct?
Thanks
JR
Jerry S
06-28-2002 13:03:08
 Re: JD 60 Powr-trol in reply to JR Coffey, 06-24-2002 11:39:36
The picture I think you refer to is merely showing that you can hang your cylinder from a special bracket you attach to the lift arm area so you can take your cylinder from one piece of equipment to the next without pulling the plugs to the powertrol.
zane
06-24-2002 18:57:42
The remote is not attached to the tractor proper. I understand that the system operates only one at the time--remote if it's plugged in and rockshaft if its not.
