JD 317 Starter Growl
Mickey
06-24-2002 07:11:43
I just bought a 317 with a growling starter. Sounds like the starter gear is not meshing properly with the ring gear on the flywheel. This tractor has the Onan conversion. When I twist the key to start the engine it growls really loud and sounds like it's about to explode. It always starts pretty quick, but boy is it embarrasing. I haven't worked on a Onan engine before. Would this type of noise come from a bad starter or does it sound like the gear engagement ? Has anyone encountered this problem before ?
One more question; is there a way to take the play out of the steering wheel ? It turns about a half turn before the front wheels start to move.
Thanks..... ..
BIG DAVE
06-24-2002 21:04:06
 Re: JD 317 Starter Growl in reply to Mickey, 06-24-2002 07:11:43
CHECK THE BATTERY SIZE AND CABLE CONDITION
HAD SAME PROBLIM W/KOHLER ON A 212 JD
LARGER BATTERY SOLVED THE PROBLEM
Henry J
06-24-2002 17:37:29
Mickey
When i have run into those starter problems, I usually first remove the cowling and get down to where you can watch the starter perform on the flywheel. That should tell the story or else it will be obvious in a glance.
4020JD
06-24-2002 15:54:28
YOU MAY BE ABLE TO LOOSEN THE STARTER AND READJUSTED IT TO MESH BETTER I HANVE EVEN DRILLED OUT THE MONTING HOLES THEN PUT WASHER BETWEEN THE BLOCK AND STARTER AS A SHIM.
