60 john deere
jody
12-15-2003 18:45:51
how do you check the oil level on my model 60 is it just up to the top inside the oil cap???
Don c
12-16-2003 03:53:59
 Re: 60 john deere in reply to jody, 12-15-2003 18:45:51
My early 60 takes 8 qt's with filter. Do like others say, get all books on it. JD plus I&T
Don c
CLW
12-15-2003 21:10:54
SamH is correct, so is JDVan. I just wanted to say by chance if you HAD filled it to the top of the pipe it is WAY WAY over full. I would drain the oil and start over with fresh oil anyway if you are not sure when it was changed last. I use 10W-30 in my 630 here in Texas, and it holds about 11 quarts. The 60 should be about the same.
CLW
Clancy
12-15-2003 20:26:22
"old" & Sam you're both right. It won't be necessary to go through some high tech engineer's rigamaroll just to check the oil!
buickanddeere
12-15-2003 19:45:09
1-800-522-7448 for a operators,parts and service manual. There are many items to check and service.
old
12-15-2003 18:57:58
I can't say for sure I'm guessing but if its like my B, by the flywheel there is a bolt in a pipe sort of thing that you open to see if the oil level is right,,its right when oil starts to run out of it.
SamH
12-15-2003 19:32:19
 Re: Re: 60 john deere in reply to old, 12-15-2003 18:57:58
That's the way you do it all right. The checking plug is under the pulley on the 60. It is a hex shaped plug, about an inch long with a hex head plug screwed into it. Park the tractor on a level place and back the plug out a couple of turns. If oil runs out the hole in the bottom, everything's fine. If not pour oil in until it runs out.
JDVan
12-15-2003 20:33:56
 Re: Re: Re: 60 john deere in reply to SamH, 12-15-2003 19:32:19
SamH:
Your response is correct for a factory configured 60. However, there was an aftermarket add-on that was sold that allowed one to use a dipstick on the 60 to check the oil. I have two 60's here, with one of each type. Just in case that shows up in this thread.
