JD B Differential adjustment?
JD JACK
06-23-2002 19:43:00
I am putting my B transmission back together (20100 and up). Going to put diff back in. Are the steel shims used on both sides (left and right quills? Or or shims just used on left-hand?
mike
06-24-2002 10:26:32
 Re: JD B Differential adjustment? in reply to JD JACK, 06-23-2002 19:43:00
I think the shims only go in the left side to adjust bearing end play as there is no backlash adjustment on spur gears.
G-MAN
06-24-2002 10:40:37
 Re: Re: JD B Differential adjustment? in reply to mike, 06-24-2002 10:26:32
According to my I&T book, there are shim gaskets on both sides of the B differential, because there are quills on both sides, unlike some of the other two-cylinders, which have the bearing cup set in the case, with a metal plug to seal the bore. This would be on B serial #201,000 and up. I would just use one shim on one side for sealing purposes, and use the rest on the other side. There is no preload on the bearings, what you want is .001" to .004" end play of the differential assembly. If using new bearings, I would try to set it on the tight side, to allow for some wear-in of the new bearings.
Henry J
06-24-2002 05:25:38
JD
I havn't done a B rear end, but it sounds like a typical one. Those shims can be on either side or both. first the total amount of shims is determined to give the right bearing preload. Then the shims are adjusted from side to side to give the correct back lash. Hope I have this one right!
