Bench testing a starter??????
James
06-22-2002 22:27:18
I know that you can hook up a battery to a starter and tell how well it turns over, but, is there any way to tell how good of a starter it is? Just because it turns over fast doesn't mean that once you put it on a tractor it will have enough power to turn the tractor over properly. Is there any way to test it?
Thanks James
Clooney
06-23-2002 04:11:34
 Re: Bench testing a starter?????? in reply to James, 06-22-2002 22:27:18
James, no load starter testing can be done but you will need a tachometer & ammeter in series as well as the no-load starter specs to tell anything.
~For home shop testing the best way is do a no-load bench test to see if it operates & spins up fast, then install it on the tractor to see if it is has the torque required to start the tractor. ~For any kind of test you will need a "FULLY CHARGED" & proper CCA battery(s)..... ....
