Clutch noise on B
Joe
06-22-2002 16:45:38
I just got done putting new facings in my 46 B. when ingaged, it makes a scraping noise, if i disingage it then reingage it it will stop. what causes it?
Clooney
06-24-2002 03:13:21
 Re: clutch noise on B in reply to Joe, 06-22-2002 16:45:38
Joe, make sure the pulley brake is adjusted tight enough, if the brake is loose it will allow the pulley to travel in to far & rub the dust shield.
~Remove the pulley cover to see if the adjusting bolts are hitting the cover [common problem with worn parts]
~If the noise is actually in the clutch it is probably oil or rust on the steel clutch driver or plates..... .....
