Deere 6030 pros and cons?
Dale B.
10-17-2003 08:59:36
Looking for a big tractor to pull a 5 chank ripper. I found and old 6030 sitting in a field that the owner who no longer farms will sell. It runs good, engine, transmission, were gone through, and clutch replaced about 1000 hrs ago. All it needs is new rubber and a paint job.
This a really rare machine around here, only seen 2 of them and this is one of them. Were they good tractors? Are parts still available from Deere?
Indydirtfarmer
10-20-2003 03:42:19
 Re: Deere 6030 pros and cons? in reply to Dale B., 10-17-2003 08:59:36
BIG and BAD. Nothing 2wd will ever touch one. Factory rated at 175 hp, most were actually closer to 225. Heavy. It takes all that wieght to hook it to the ground. No one bought one of them to mow grass with. They got worked. Big impliments, in big fields. Check tranny/rear end gears for wear. They're worth having around, if you ever get anything else stuck. The most "awsome" looking tractor ever made.
Glen in TX
10-18-2003 23:11:09
Have a 1976 6030 still running hard on its second engine. Overhauled the 531 but found out later it would have been less to trade up to a 619. A rod bearing spun and had to get a new crank. Depends on what kind of ripper, subsoiler, or combo rig you have? We pull an 11 shank big ox ripper with the 6030 in 3rd or 4th gear and use B1 on a 4450. 20" shank spacing on big ox ripper. These tractors were made to lug all day long to get the job done. I have seen pictures of where someone put a SG cab on a 6030. They should have done that from the factory but then they wouldn't sell as many new ones.
G-MAN
10-17-2003 10:19:56
The 6030 is generally a good, strong tractor. They are basically a 5020 on steroids. They were available with two engines - either a naturally-aspirated 531 or a turbocharged and intercooled 531. The turbocharged ones seem to be far more common. At Stuart mentioned, there are also quite a few running around with the 619 engines, as it's an easy swap. The transmissions and differentials are built very heavy, and will withstand all sorts of abuse. Most of the turboed ones will run in the 220 or so horsepower range, although they were rated at around 185 or so from the factory. They'll pull like a locomotive, but it is going to like it's fuel. I would guess that in a good hard pull, they'll burn something like 15 gallons per hour or so. That's to be expected, because it takes a lot of fuel to make that much horsepower in an older engine like that. I have a friend that once farmed with three of them, and now has two, and he loves them. He always claimed that they'd pull a 4850 around backwards, and he might be right. The only major drawback when comparing them to newer iron is that they only have the eight-speed synchro-range transmission. A lot of guys looking for a tractor in that power range want some powershift capability, but if you're going to pull it hard, you can just put it in gear and go. They have enough torque to lug through the tough spots. If it's had all the work you say it has, I wouldn't be afraid of it.
Stuart
10-17-2003 09:17:22
I hope u got at least 230 hp to pull that ripper if it goes as deep as ours does.
They were a real good tractor and yes u can still get parts for them. Does it have a 531 or a 619 engine. I think i got those numbers right but not sure if they came with a 619 I know guys who put them in. We have a 5 shank ripper and it takes all our 8410 MFWD has which is about 240
Is it a three point mount, mine has disks on both ends of it which makes it pull a lot harder
Good luck
Dale B.
10-17-2003 11:14:03
 Re: Re: Deere 6030 pros and cons? in reply to Stuart, 10-17-2003 09:17:22
You must have some really heavy soils. I currently have the ripper set up as a 4 shank, and I have pulled it with my 4440 as well as my turbocharged 4230. The 4440 and the 4230 with the M&W will both roll right along with it, but I have to downshift if I hit a clay spot because they will start lugging. I also have to put a full rack of weights on to keep the front wheels on the ground. Dad and I built this ripper in our shop from a set of plans he got from the Stoneville Agricultural experiment station. The original plans called for a fifth shank but we cut it down to four, We went ahead and built the toolbar long enough for all five shanks, and had the fifth shank made in case we found a bigger tractor to pull it with. I think this old 6030 would probably pull the ripper just fine, but I just wondered if it was worth messing with or if I should look for a 4630 or 4640 or maybe even a 4840 if I can find one. I know where I can buy an 8430 with a brand new engine, from a guy who is retiring this fall, but I have heard those articulated 4wds are more trouble than they are worth.
JD 5020 guy
10-17-2003 16:18:00
 Re: Re: Re: Deere 6030 pros and cons? in reply to Dale B., 10-17-2003 11:14:03
A 6030 might not have a powershift transmission or SG cab, but I you can buy them around here for usually the same price of a 4020.
Stuart
10-17-2003 11:36:24
What I mean is that we have a DMI eco tiger
It actually deep till not a ripper. Technically speaking a deep till goes deeper than a ripper.
Its a trailer model not a 3 point mount. it was two sets of angled disks on it front and back of the shanks. Our 4850 had a good time pulling it and so we bought a 8410 with about 240 hp and it pulls it great
We also have a 9 shank glencoe that takes a 8410 to pull because it is natuarally a hard pulling chisel and it goes 16 deep and it has 6 inch sweeps on the shanks. We like to pull it 8 mph and the deep till about 6.5. I guess it depends on how fast you want to get your work done
