40T Hard starting in cold weather
Chuck NH
12-15-2003 16:27:33
My 40T has always been a dependable starter, but the last few times I've gone to use the tractor, it's really tried my patience! It cranks over good, but as it fires, the starter kicks out and I'll end up flooding and wetting the plugs. Any suggestions as what I can do? Thanks in advance...
Clooney
12-16-2003 06:05:32
 Re: 40T Hard starting in cold weather in reply to Chuck NH, 12-15-2003 16:27:33
Chuck, not real sure from your post if your problem is in the actual starter or an engine starting problem that allows the starter drive to kick out while cranking..
~The starters on those Dubuque's do kick out easily if it fires enough to speed the engine up slightly while cranking..
~I guess the place to start is to crank the engine with the ignition switch turned off.. If it cranks good & the starter stays engaged your starting problem MIGHT not be starter related..
~If the starter cranks good in the above test, probably the next easiest thing to check is to by-pass the tractor's primary ignition circuit & jump power from the starter's big battery stud directly to the ignition coil's NON distributor side.. If that helps the starting problem you might have resistance in the ignition switch [somewhat common on the Dubuque's], or resistance in the dash fuse holder, or resistance in the primary wiring.. If the jumper wire helps the starting use a voltmeter & measure the coil's non distributor side while cranking to see if it's much below 5 volts. Then measure it at both the battery & coil during cranking & see what your voltage drop is between the two..
~If the by-pass test doesn't show a starting change you might try cranking it with a battery charger hooked to the battery during cranking.. It doesn't take much of an old, low charge, or sulfated battery on those 6 volt systems to lower the coil's voltage enough during cranking to only allow a good spark when the starter is released or kicks out. [if the battery charger helps, you might need a better battery].. A low battery & poor spark during cranking can show up as fouled plugs if it doesn't start right off.
~If your tractor still has old or summer gasoline in the tank you might want to drain that & replace it with good fresh winter gasoline [there is a difference] .. Summer gasoline doesn't start worth a hoot in cold weather.. [your starting problem might be as easy as that]..
~As Wayne said, try a new set of spark plugs.. In a lot of cases that is all it will take.. Those Dubuque's are sensitive to spark plugs & once they foul they tend to foul easier the next time.. I prefer different plugs than Wayne but the idea is new not what brand..
~Try different throttle & choke settings, sometimes just a little different throttle or choke setting can make a big difference in starting..
~Can give us a little more information on how it acts during cranking, like how much it fires while cranking, does it try to run at all then quits, if the starter kicks out before it even fires, if it runs a few seconds before it quits & the plugs foul. [the more info you can give us the closer we can get with the help]
[email protected]
AR Roger
12-15-2003 18:58:21
I'm not really sure about the starter on a 40, but it certianly sounds like a weak starter drive (bendix) or the solonoid on the starter (if it has one) isn't holding the drive into the ring gear. Other more expierienced (John T, Clooney)guys will be more help. Good luck!
tom
12-15-2003 17:07:32
Chuck,
Howdy...have an MT which is very similar to the 40 in many ways...I would first pull my starter and examine to see why she is quiting on you: bad/loose wiring or connections with a host of internal parts. Does it just quit or does it sound like it is shorting on you...
Also, go back to the basics and ensure all your cables are clean with good connections and a good ground...also, are you getting good sparks?
let us know,
tom
Chuck NH
12-16-2003 04:05:53
 Re: Re: 40T Hard starting in cold weather in reply to tom, 12-15-2003 17:07:32
I replaced the battery cables about 3 years ago and a new battery, points, cap, rotor, and wires (copper core) a year ago. Use Autolite plugs (can't remember # offhand) and replaced them after the last hard starting event. The starter does continue to spin after the bendix kicks out, so I suppose that could be weak. Thanks guys for your ideas.
Wayne in Tn.
12-15-2003 17:44:30
Chuck, since you mention wetting the plugs a few times, I would start with a new set. I have good luck with Autolite 216.
