720 wont come out of gear
Les
10-17-2003 08:58:51
Got a 720, there must be a gear problem, as it grinds in 1st and 3rd gear, real bad....but it works in the other gears...sometimes....
Last week I backed it in the shed, took it out of reverse and put the clutch forward and turned it off. the pony doesnt work so to start it, we have to pull it...Now, it is stuck in some gear and I cant get it to come out of gear so I can pull it....the gear shifter moves around, but it is still stuck...tried turning the clutch to get it out, but it is still stuck in gear....wondering if I did get it running, if it might pop out...but I cant pull start it right now as I cant get it rolling...please help..what is broke or wore out in my tranny?
Clooney
10-17-2003 09:11:28
 Re: 720 wont come out of gear in reply to Les, 10-17-2003 08:58:51
Les, it sure sounds like it is stuck in two gears at once. ~You will probably have to pull the trans top cover to re-align the shift rails. ~I wouldn't try to force it or start it & use engine power to force it out of gear as it is easy to break the tans or bend a gear shaft.
~You will have a hard time moving it with it the way it is now. Even with the clutch disengaged the trans is still locked up & that won't move easily.
~Sometimes you can jack the rear of the hood up enough to pull the shift quadrant & reach in & manually move the shift rails into neutral�
~Once apart check for loose trans bearings, or a worn shift lever lower fulcrum & ball, or worn edges on the shift fork slots.. [the most common reasons the trans locks in two gears at once]�
[email protected]
