Cotter pin
David Ransom
06-20-2002 21:59:48
Is there a least difficult way to remove a right connecting rod cap bottom bolt's cotter pin? Vise grip?
Larry
06-21-2002 06:53:20
 Re: Cotter pin in reply to David Ransom, 06-20-2002 21:59:48
David, This may seem pretty trivial but you ask! You need to turn flywheel where you can get best access to the rod bolt. If the cotter pin is wrapped tight against rod nut then use screw driver or small chisel to bend away from nut. Then take your pliers or vise grip to bend the two pieces together and simply pull out. If that fails then take a good side cutter plier and cut off the two bent legs and pull out. If you do this remember to fish out the pieces you cut off.
JDBob
06-21-2002 08:23:51
 Re: Re: Cotter pin in reply to Larry, 06-21-2002 06:53:20
Larry,
If that cotter pin is stubborn to get out I've had good luck going ahead and getting the two "Legs" straightend out and bent toghether as well as possible and then got ahold of the head of the cotter pin with a pair of side cutters "Just enough pressure to kinda bite into the head of the pin, not too much or you'll cut it" Then tap the bottom side of the side cutters with a small hammer. This has pulled a many stubborn cotter pins for me. Like I say just be careful or you cut the whold head off the pin and sometimes it flares it where you can't go either direction with it.
If the head does get cut I've even had to use a real small punch to help knock the pin out.
JDBob
