50 carb. problem
JP
06-20-2002 18:53:30
Have a 50 that was running fine, bottom stem stripped out on carb. Sent it to a reputable carb shop, told them to fix stem and if needed rebuild. Got it back today and installed, will run on no.1 cyl. only, good spark both sides, adjusted no.2 every way. Could this be a carb. problem???
Kerry
06-21-2002 08:54:16
 Re: 50 carb. problem in reply to JP, 06-20-2002 18:53:30
There were 2 different carbs on a 50, a one barrel and a "duplex" like on a 60. If your carb doesn't have the divider where it bolts to the manifold, it can't affect only one cylinder so the problem is somewhere else. If it's a duplex, maybe you have a problem on one side.
Hope that gives you a start!
Kerry
JP
06-21-2002 10:58:57
 Re: Re: 50 carb. problem in reply to Kerry, 06-21-2002 08:54:16
It's a dltx75
Sound like a Dennys screw job
06-21-2002 06:04:17
