Front axle M
vic
06-20-2002 14:53:33
I built a new front axle for the M, put it back together, and it steers opposite, only because I cannot believe the tie rods cross over the axle to connect to the pitman arms. Is this right?
vic
06-20-2002 18:58:01
 Re: Front axle M in reply to vic, 06-20-2002 14:53:33
Thanks for the reply Mike, after your description, I believe the assembly may be in backwards. Just not sure what to do about it now.
mike
06-20-2002 18:26:21
I just went to look at my M the arms on the spindles point to the front the tie rods run at a slight angle to the rear but do not cross the axle just end up about on top of it.The axle goes to the rear of the housing with the longer part of pivot tube to the front. Hope you can make some sense of it ,do you have the assembly in backwards ?
