GP Tractor value
steve
06-20-2002 11:33:08
I resently bought a GP #223796 or 798.
the last number is hard to read. i have read
that 796 is the last small bore, and 798 is a
crossover tractor. my question is what value
is. it is all there and tries to start. also has power lift.
David
06-21-2002 11:35:17
 Re: GP Tractor value in reply to steve, 06-20-2002 11:33:08
Steve:
The value of the GP will be bases alot on the conditon of the tractor and the accesories. The basic GPs that are complete and running in this area have been bringing in the range on $2500 to $3500. If the the tractor is restored I have seen a GP bring $7500.
The most disired small bore GPs are the first few hundred made. Then in the large bore is the tractor made in 1934. The cross over GPs are in completely different class. If you have one that is complete and running should be in the $8000 to $10000 range.
A few of the accesories that are condered desirable, steel wheels, side hill hitch, and powerlift. Implements for the GP are also very sought after.
I would suggest tring to get a better look at the serial number or see if the tractor posses the feature of a cross over.
