8430 starter motor problems
rich uk
12-15-2003 12:27:50
help
i have an 8430 jd articulated tractor every morning you go to start it it spins over then slows up during cranking,so i fitted new batteries. next morning same fault!..
so i put new alternator on it a 120 amp instead of a 60 amp .next morning same fault.put another set of batteries on and new leads new earth wires isolator switch .it still wont spin fast when cold ,but if you jump it off another vehical it fires up .once warm it spins over fast
had engine checked over by our local jd dealer everything found good
is it possible for the starter to be at fault?
is it possible the hydraulics causing to much load?
any help would be great as im ready to throw the towel in
cheers richard
Brokenwrench
12-15-2003 13:16:14
 Re: 8430 starter motor problems in reply to rich uk, 12-15-2003 12:27:50
You probably have an internal hydraulic leak,causing the pump to start pumping while cranking. Try turning the steering wheel back and forth while cranking, this usually unloads the pump so it will spin over faster. Your tractor may or may not have an electric destroke solenoid on the main pump. This unloads the hydraulic pump while cranking. If you don't have one, your dealer can supply you with a kit to install one. Also if it doesn't have one, there is a manual destroke valve that does the same thing. It is a Tee shaped screw on the pump, turn it in finger tight, start the tractor and then back it back out. If your tractor does have one, you could have a bad solenoid or wiring problem rendering it inoperative.
