Answer to clooney
Tracy in ND
06-18-2002 20:51:54
Clooney: You asked for a reply if I found the answer to the AR oil pump loosing its prime. My neighbor (who happens to be a plumber) came up with a dandy suggestion. He said to install a brass flapper check-valve in the 6'' pipe connected to the pump. WOW!! since this installation, not ONCE has the pump lost its prime. Total cost, $11.37.
Tracy in ND
Clooney
06-19-2002 03:09:12
 Re: answer to clooney in reply to Tracy in ND, 06-18-2002 20:51:54
Tracy, thanks for the tip on the check valve. ~I have seen the check valves you are talking about & will try one on the next early "A" that has a priming problem..... .
