Clutch on 39B
Brian
06-17-2002 18:37:09
I cannot get the clutch to disengage. I had the clutch and drive gear off as a set. I did not take the clutch apart. I had the rear end off, the flywheel off, and the clutch lever off. Now when I pull back on the clutch arm the clutch snaps and moves out slightly, but does not disengage. I took it off and put it on again to check things out and after installation it still won't disengage.
Does anyone have any ideas? I know that I am doing something wrong, but I don't know what. The service manual is vague in this area.
Thanks
an idiot
06-17-2002 18:40:18
 Re: Clutch on 39B in reply to Brian, 06-17-2002 18:37:09
It sounds like you might have those three nuts on the right end of the belt pulley too tight.
DON
06-17-2002 18:58:18
 Re: Re: Clutch on 39B in reply to an idiot, 06-17-2002 18:40:18
Mimi you are the fattest person I know. Wait, I am thinking about you
