An A Question(pistons)?
Jack
06-16-2002 07:14:03
Ok,now I have some info on the pistons I have but I need another question answered.Will A2582R pistons make higher compression as opposed to some other oem JD pistons?I am wanting to make a strong A and already have these.If I can use them then I will,but I may go with some M&W's if these are not going to help my compression.Thanks
Seamo
06-16-2002 11:57:15
 Re: An A Question(pistons)? in reply to Jack, 06-16-2002 07:14:03
Jack,The distance from center of pin to top off piston is called compression distance. The longer this distance is the higher compression. Taking into fact the top of piston,dome? concave? I like to deal with Jerry Hinrichs Repair he has all the different piston combinations you need.He is very knowledgeable on 2cyl Deeres, Pistons and tractor pulling.His phone is 815-778-1900 Earl
Jack
06-17-2002 05:13:37
 Re: Re: An A Question(pistons)? in reply to Seamo, 06-16-2002 11:57:15
They pistons have a nice dome on them,thats why I wanted to use them.I have not measured the distance from the wrist pin to the top yet.Thanks
