John Deere 50 question
David Ransom
06-15-2002 21:26:49
In removing the block, I assume it is necessary to remove the studs that hold the head? What is the best way to remove the studs?
Will P
06-15-2002 23:17:19
 Re: John Deere 50 question in reply to David Ransom, 06-15-2002 21:26:49
You don't need to remove the studs. Us them to help you remove the block. If you are going to deck the block. You will have to remove them. For my 43B the studs were going to be about $120 for all. I had a stud remover(sears). I used heat. But not on the stud. You heat up around the stud (the block). I reused the studs and I work this tractor. It is not a parade tractor. It works the field. One warning. Only reuse studs that are black. Those are hardened studs. If they are just plane metal. You will have to replace. But they are probably hardened black studs. Well, good luck and good night.
Will P in WI
David Ransom - Confused
06-16-2002 10:38:30
 Re: Re: John Deere 50 question in reply to Will P, 06-15-2002 23:17:19
You don't need to remove the studs. Us them to help you remove the block. If you are going to deck the block. You will have to remove them.�?
So do I need to remove them, or not? If I am going to remove them I have to deck the block?
JDJACK
06-16-2002 15:53:42
 Re: Re: Re: John Deere 50 question in reply to David Ransom - Confused, 06-16-2002 10:38:30
No you do not need to remove the studs to remove block from tractor. But if you are going to deck the block (shave metal from where head bolt to) you will need to remove them. What are you taking block out?
David Ransom
06-16-2002 16:26:07
 Re: Re: Re: Re: John Deere 50 question in reply to JDJACK, 06-16-2002 15:53:42
No, I don't plan on shaving metal from the 50's block.
Will P
06-16-2002 21:00:39
 Re: Re: Re: Re: Re: John Deere 50 question in reply to David Ransom, 06-16-2002 16:26:07
Like G Taylor said. I redid my B motor now three years ago. Well last year I was getting water in #1 cylinder. Well apart it came again. Just 2 years old. Lost the head gasket. Block or head warped? Don't know. But I wanted it flat because I didn't want to pull it apart again for a long time. If you have the block out and tore down this far. Pull the studs and have the block and head decked. I know that you would not want to do this a couple years from now again. Learn from my mistake.
My 2 cents
Will P
G Taylor
06-16-2002 17:08:58
Get a straight edge & check for warpage after cleaning all the rust & gasket off. Much easier after removing the studs by the way. It costs little & now's the time to remove the studs & deck a few thou off the block. Best way to ensure no leaks with a flat surface with a little "tooth" to grasp the gasket from a medium abrasive wheel in the surface grinder. It's anoying to start up a freshly rebuilt engine that leaks.
puller
06-15-2002 22:12:43
if you plan on reusing them get a stud puller. sears sell one that works pretty good an isnt much money. if you dont plan on using them again then a pipe wrench will work but it will mar the stub pretty bad
David Ransom
06-15-2002 22:22:24
 Re: Re: John Deere 50 question in reply to puller, 06-15-2002 22:12:43
Well, I hope to reuse them, but JD Jack says I don't need to remove them. Is he mistaken? How is marring them bad?
JD JACK
06-15-2002 21:35:33
You do not have to remove thoses studs to get block out. I have found the best way to remove them is with a pipe wrench and NO HEAT. Removed some on an A block the ones that i heated up, bent or broke.
David Ransom
06-15-2002 21:37:56
 Re: Re: John Deere 50 question in reply to JD JACK, 06-15-2002 21:35:33
Thanks
David Ransom - another question
06-15-2002 21:54:56
 Re: Re: Re: John Deere 50 question in reply to David Ransom, 06-15-2002 21:37:56
There are two things in the platform, one on each side of the seat, that look like they are probably oil fill plugs. Are they for the back axle? They are very very rusty. If they are oil fill plugs, is there a way around them?
Bob K
06-18-2002 06:01:20
 Re: Re: Re: Re: John Deere 50 question in reply to David Ransom - another question, 06-15-2002 21:54:56
The two slotted flathead bolts hold down the platform (or step plate). They are a tapered head bolt and you will probably have to weld a nut on top of them to turn them out. That's what I had to do on mine. That is, if that's what you're describing.
