B Transmission
JD JACK
06-15-2002 13:51:40
Putting transmission back together on late model B six speed. It would jump out of gear under a load. Got two different gears, other one had some broken teeth. Installing all new bearings. Was there some sort of lock that could be installed to prevent them from jumping out of gear? Thought that I heard that john deere came out with something like this. Also installed new spring for detents. What to make sure that it's fixed the first time.
ChuckW
06-15-2002 17:51:23
 Re: B Transmission in reply to JD JACK, 06-15-2002 13:51:40
Please give us more information when the tractor jumps out of gear....maybe we can help
JDM Guy
06-15-2002 15:09:06
My M did that some times so I got in the habbit of holding the shifter when going up hills. The reason is most likly the broken gear teeth.
JD JACK
06-15-2002 19:04:55
 Re: Re: B Transmission in reply to JDM Guy, 06-15-2002 15:09:06
The shift level doesn't pop out. Pulling disc and tractor will be working, will hear load bang and clutch will stay engaged, shift level will stay in slot, but will not move. Have to disengage clutch, and reshift back in gear. Replaced countershaft idler gear had broken teeth and replaced transmission drive gear (pitted bearing race).
