JD 420 high exhaust low trees
greg
06-15-2002 06:20:45
Greetings ,I need a little info on changing exhaust on early JD 420T from vertical exhaust to some kind of horizontal exhaust, I use it to mow around the place and I have lots of trees with low branches, really tired of knocking muffler loose, Have seen pictures on exhaust sorta diagnol and others with muffler horizontal and towards the front on top of tractor,, My exhaust has a flange broken so if anyone knows where to buy ?orchard? manifold please advise also open to any other fixes thanks greg
Wayne in Tn.
06-15-2002 11:52:53
 Re: JD 420 high exhaust low trees in reply to greg, 06-15-2002 06:20:45
Greg, an orchard or side exit manifold was available for the 420 the part number is M3957T The downswept muffler is part number AM3224T I have just bought the muffler from Deere it is $130 I don't know if the manifold is still available or not, might find a used one.With the above manifold, you can put the muffler at any angle or horizonal. Also there was a tail pipe that ran underneath the axel, but it is no longer available from Deere. It could be made at a muffler shop. Wayne...
