1974 JD 112 Stuck in Reverse
Dan Potter
12-15-2003 07:48:01
Was plowing snow yesterday and shifted to reverse and back out but she stuck in Reverse. Is there a lever disconnected to the gear box, am I stuck between two gears, or Worse!?
What do I need to do to free this up?
Dan
mike
12-15-2003 15:59:50
 Re: 1974 JD 112 Stuck in Reverse in reply to Dan Potter, 12-15-2003 07:48:01
sounnds like the bottom of the shifter broke i replaced my shift lever las winter when it had the same problem if u like e mail me back an ill tell ya how to ck it out an how to fix it
F-I-T
12-15-2003 10:13:25
Dan:
It's been a long time since I had a transaxle like that apart (on a 214), but there are a few things you can try.
First, you can slip the drive belt off of the transaxle (underneath on the right side?) and see if that will let you jiggle and wiggle while moving the gearshift and axles, to get it to release.
If that doesn't help, you'll probably have to remove the fender deck, and then remove the gearshift lever. This should allow you to see what might have happended, what might be worn or broken, or just reposition everything and reinstall the shift lever.
BTW if you have to go into that transaxle, the service manual from Deere is really helpful.
Frank
Putt Putt
12-15-2003 12:07:20
 Re: Re: 1974 JD 112 Stuck in Reverse in reply to F-I-T, 12-15-2003 10:13:25
Hey Frank---
How inclusive are those L&G manuals?? I wonder if I could get so lucky as to get a shop manual and/or Parts Cat that covers all of my small Johns (180 and LX188). I have the owner�s manuals. With the boost in manual prices from Mother Deere, I gotta pick and choose. I use two LX188�s and have thought about restoring the old stick shift 180.
Putt
F-I-T
12-15-2003 14:07:04
 Re: Re: Re: 1974 JD 112 Stuck in Reverse in reply to Putt Putt, 12-15-2003 12:07:20
Putt:
I had the parts, ops, and service manuals for my 214, it was really helpful. They are just like the tractor books. I know they are expensive, but I had obught my 214 in pieces, and really need it to go through it properly.
Frank
