JD 420 aftermarket tie rod
reefsan
06-13-2002 15:27:14
anyone know where you can get tie rod ends (new) for my 420? Dealer is expensive and Yesterday's tractor doesn't have the ones I need (inside ones)Thanks for the help.
Henry J
06-13-2002 18:47:19
 Re: JD 420 aftermarket tie rod in reply to reefsan, 06-13-2002 15:27:14
reefsan
I got mine at NAPA. We had a good local NAPA. I took the JD rods in and asked the guy to go back and take a stab at matching the ends with auto parts. He brought out perfect fits on the first try. I had a friend that was a heck of a lot better at welding than me. He cut the ends off my Jd rods and welded the ones from napa on. They look like they belong there, have grease fittings and have since been painted green. It is best to try not to overheat the ends if you are not sure they do not have nylon components inside. Go for it.
Wayne in Tn.
06-13-2002 17:52:41
Reefsan, I am not sure, but have heard that some of the old model Chevys are the same. You might try comparing them at NAPA, Carquest, Ect. If so they would be cheaper.
reefsan
06-13-2002 19:05:06
 Re: Re: JD 420 aftermarket tie rod in reply to Wayne in Tn., 06-13-2002 17:52:41
thanks for the advice guys, I'll give it a try.
