JD 1010 Serial Number
Donnie
06-13-2002 03:16:04
I have a John Deere 1010 and trying to figure out the model of it. Where is the serial # located? I am sure there is a tag somewhere but I have not been able to find it. Thanks for your help. Also I see very little discussion about the 1010. Is this not one of the more popular John Deere tractors of the past? I do love mine.
Donnie
06-13-2002 06:44:19
 Re: Re: JD 1010 Serial Number in reply to Loren , 06-13-2002 04:53:31
Thanks
G Taylor
06-13-2002 08:33:30
 Re: Re: Re: JD 1010 Serial Number in reply to Donnie, 06-13-2002 06:44:19
If the serial number plate has gone AWOL, we can narrow the serial number range down to four or five versions. Depends on type of shifter, hydraulics, number of bolts holding the trans to the center torque tube etc.
Donnie
06-14-2002 02:03:03
 Re: Re: Re: Re: JD 1010 Serial Number in reply to G Taylor , 06-13-2002 08:33:30
I did not to a real thorough check as I was in a big hurry today but I did glance at the 1010 looking where yall said the serial number would be. I did not see it anywhere. Is it cast into the block of the motor or is it on a metal tag somewhere? Is it kind of behind the distrubator area? Would I have to take the hood off to see it? Apparently it is not in a obvious location because I surely did not see it anywhere. Thanks for yall's help.
Donnie,]
Loren
06-14-2002 03:27:55
 Re: Re: Re: Re: Re: JD 1010 Serial Number in reply to Donnie, 06-14-2002 02:03:03
Mine is in the open area right behind the generator and just a little below it. It is a plate attached to the engine block.
