Wayne in Tn.
12-15-2003 06:19:17
Re: 320 3 point won`t move in reply to Rusty, 12-14-2003 21:32:14
Rusty, I have rebuilt several of those touch-o-matacis lately, with good success, but its hard for me to diagnose a certian problem. I usually just tear them down, clean good and replace all the soft parts,ie. seals, rings, o-rings ect. First, I'm not sure what type of fluid you have in it, but Deere says to use 10w non-detergent motor oil. This is the cheap stuff at Wal-mart ect. I have also used 30w non-detergent. You have performed the first test that I would do. If you loosened the SMALL line at the front of the unit, that is the pressure line, and you should have had a good squirt of oil from it, with the engine running at fast idle. The BIG line is the suction line. If you show no pressure at the small line, then it is a problem at the pump or the big line is sucking air somewhere. Did you check the coupling that runs the pump? It is mounted on the camshaft with a couple of bolts. That is the first thing you have to have, is pressure at the SMALL line. Try changing to the non-det. motor oil, check the pump coupling and post back, maybe we can figure it out.
